Hey guys...
Was working in a model just fine. I ran a solution and realized I had a surface constrained wrong. I changed the constraint, saved, and went to solve again. This error poped up:
Linear StressForm Load
Error No.: 75
Error Description: The specified Path/file name cannot be accessed or is invalid
Error Source: RichTextCtrl
Line Number: 1980
Options are Abort, Retry and Ignore. None of the options seem to do any help. My model is now unsolvable? This really throws me for a loop as I have not move or changed the name of the file. Infact, never closed Algor inbetween solves.
Any thoughts would really be great. Thanks in advance!
Did this happen in the same version Algor or two different versions?
If it's the same version, did you move/copy your original model? Maybe the path includes non-English characters or is too long.
Same version of algor used, infact, same open session. Never closed the model. The only thing that changed was the surface contact constraint, then went to solve again right after, which was when I recieved the error. Prior to that, I have successfully obtained a solution.
How about switching back to the "wrong settings" in your original model?
If the old setting works, it means something wrong in algor.
If it fails too, it means something else. Maybe you can backup your model, restart algor and try it again with both old and new settings.
There seems to be no setting I can change to get it to work. I will be re-creating the file. Something got lost at some point? One of them errors that just can not be explained i suppose.
Thanks for your suggestions!
It seems a file-access-confliction issue.
This could be caused by system or software.
For example, the previous analysis is aborted in inappropriate ways.
If so, sometimes, you have to reboot the system to have files unlocked.
You can right-click and "copy" the design scenario to a new one, and then run the new one to check whether the error is still there.
-Shoubing
@BEC_Kevin wrote:There seems to be no setting I can change to get it to work. I will be re-creating the file. Something got lost at some point? One of them errors that just can not be explained i suppose.
I will have to keep that in mind for next time!
I re-created the scenario and had no issues the second time around.
Thanks again all for your thoughts!
