Hello All,
I am running a MES with nonlinear material model and approximately 800,000 elements. Element definition is von Mises curve with isotropic hardening.
I am consistently getting the following error message:
Error # 321 was generated by RichtextCtrl
Invalid file format
Line number: 0
In addition, the report file is 3.5 GB, and it does not seem to load from file.
Does anyone have any suggestions?
Thanks.
Matt
The RichtextCtrl is an OCX file used by VB in the Analysis screen. It seems that your multi GB log file may be causing problems while it is trying to be displayed in this screen. Does this error occur for other models? If not, then the problem is model dependent and may be addressed by ensuring additional output is not included in the log file. Have you changed output options prior to running your analysis?
