So I had a question about constraining a specific area of a surface. Say for instance, you have a beam and you want to constrain both ends of the bottom surface. Is there a faster and more efficient way of selecting the bottom surface nodes to constrain instead of selecting them one by one?
I pretty much want to constrain one part of the bottom surface from moving at all while having a displacement constraint on the rest of the piece.
If you have a CAD solid model and you wish to add a load/constraint to a small patch of a single large surface you have at least 2 options.
1) Split the large surface in to smaller sub surfaces using a CAD package. Inventor Fusion (which is included with Autodesk Simulation Mechanical is a good tool for this)
2) use the "rectangle" select tool to select all the "vertices" you wish to constrain, and then add the boundary condition.
The only problem with the rectangular select tool is that it selects that entire plane that the node is on and I only want to constrain the bottom surface of the piece.
If you are still struggling with this issue please feel free to attach an image of the area of interest (or your simulation Archive file), so I can give you more specific directions.
You can do it by creating two splits on the bottom surface in Inventor before importing it so simulation, and adding a surface constraint within simulation.
This video shows how to add a split using inventor fusion, which is basically the same in inventor.
http://engineeringexploration.autodesk.com/content/module-2-editing-non-native-imported-geometry
Hope this helps
