Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Combining Surfaces
2 REPLIES 2
547 Views, 2 Replies
Combining Surfaces
I am running an electrostatic field strength and voltage simulation for a MEMS device, but am having a problem specifying the "Invoke Force/Charge calculation" surfaces.  I have a lot of surfaces that I need information for, and was wondering if I could specify only one surface.
I saw in a tutorial, located here, in which multiple surfaces are combine into one surface.
I have been looking for a long time on google and these threads, but have not found any way to do this.
Thanks a lot for your help,
Mike
2 REPLIES 2
John_Holtz
Hi Mike,
Select the lines that you want to change. The easiest method is to first select all of the surfaces ("Selection > Select > Surface" while holding down the Shift key), then select the lines on those surfaces ("Selection > Subentities > Lines").
Change the surface number of the selected lines. ("Draw > Modify > Attributes")
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
in reply to: John_Holtz
Thanks a lot,
You have saved me a lot of time!
