Discussion Groups
Simulation Mechanical and Multiphysics
DonaldR.Culp7481
Accepted Solution
Combined stress: static + dynamic?
213 Views, 2 Replies
08-29-2013 10:22 AM
Hello --
If a run a static stress analysis and then run a dynamic analysis (modal, then frequency response) on the same model to get the dynamic stresses, is there any way to combine the static and dynamic stresses to find the maximum total stress? I know that I can do this by exporting the results to Excel and then combining the stresses there but I'd like to do this within FEMPRO so that I can also see the stresses graphically (superimposed on the model). This would be useful to see if a certain stress level (e.g., yield) has been exceeded.
Linear models, Simulation Mechanical v.2012 (v.2014 also available)
Don C.
Please use plain text.
Valued Mentor
AstroJohnPE
Re: Combined stress: static + dynamic?
08-30-2013 10:29 AM in reply to: DonaldR.Culp7481
Hi Don,
Look into the command "Results Options > Other Tools > Combine Load Cases" (in the Results environment, of course). I know that it was expanded to permit static and dynamic results, but I do not remember if it includes all of the dynamic processors.
One word of caution for you and other readers. Some of the results of the dynamic analyses are "all positive". For example, the cases that are some type of resultant, such as a square root sum of the squares (SRSS), have all positive directions (sqrt(displacement^2) even though it may not be physically possible. You probably do not want to combine such results with the static stress analysis.
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
16 years experience with Simulation Mechanical
DonaldR.Culp7481
09-09-2013 07:09 AM in reply to: AstroJohnPE
Thanks John. That's what I needed.
