When running an Analysis job on the cloud, I get the following error:
Autodesk (R) Simulation Static Stress with Linear Material Models
Version 2014.01.15.0033-W64/X64 15-Aug-2013
Copyright (c) 2013, Autodesk, Inc. All rights reserved.
Error: unexpected analysis type ( 1), wrong design scenario?
Cloud submission started: 09-29-2013 22:51:34
Cloud submission finished: 09-29-2013 22:53:28
Total Cloud elapsed time: 2 minutes, 53 seconds
Job failed
When doing a ''Check Model'' I get the following message:
fem2esh - Make esh file from fem file for a specified design scenario
Version 2014.00.15.0190-W64/X64 21-May-2013
Version of fem2esh.exe : 2014.00150190
Version of dcx1-win-x64.dll : 2014.00150190
Version of femapi-win-x64.dll : 2014.00150190
Version of agsdb_ar-win-x64.dll : 2014.00150190
Version of tsx2tsy.exe : 2014.00150190
Input Model : E:\VM1\Machine\Upright\Upright8\upr8_TripleUpright_Simulation_1.ds_data\1\ds
Input File : E:\VM1\Machine\Upright\Upright8\upr8_TripleUpright_Simulation_1.fem
Output File : E:\VM1\Machine\Upright\Upright8\upr8_TripleUpright_Simulation_1.ds_data\1\ds.mod\group.esh
Log File : E:\VM1\Machine\Upright\Upright8\upr8_TripleUpright_Simulation_1.ds_data\1\ds.mod\group.ldx
Design scenario : 1
Analysis type : Linear Stress
Start time : 2013/09/29-22:43:44
--- Get 93 active element parts in range [1, 93] from fem file
--- 2 enabled L&C groups are defined
--- Get 658806 points defined in range [1, 658806] from fem file
Calling the Surface Topology Generator (tsx2tsy)...
tsx2tsy: Update part surface contact/bonding data (duration=4 sec.)
Making interior points for midside nodes...
--- Made 377353 interior points for midside nodes
Set up nodal properties such as admissible BC etc. by adjacent elements...
In working on FEM file for a FEA model
Terminal Error: FEM2ESH#63
NO_3D_ELEMENT: please check meshing phase 10
2013/09/29-22:43:51
I do not know what "meshing phase 10" means, and how to check it.
The meshing went OK without error, so I do not understand it.
What is wrong here?
I've had issues like this before, and I've had decent results just by deleting the mesh and running it again. I had a terminal error that happened on a model that I had run and meshed previous and only changed a load.
