Autodesk Simulation 2012
In the model I'm currently working with, I attempt to change the feature matching setting and after I do so and select apply, I then go to close the window and I get a pop up saying that there has been an error (generic, fill out email address, what were you doing when problem occured, etc). This happens wheather I change the setting in the parts tree or through the option in the Mesh ribbon area.
Very frustrating as to why this is happening, any ideas?
Thanks in advance for any and all help.
