As the title says, I was wondering if there's a possibility to visualize the LPF (Load Proportionality Factor) or Load Level in Algor? It would be a handy tool, I think. I haven't found anything in the results menu or the help file.
Björn
Solved by S.LI. Go to Solution.
As shown here, the last column in log file displays the load level.
I don't think this can be found in post-processor so far.
Time Percent DT L Iter. Residual Load Level
0.500000 0.00 1.000000 1 0 0.0000E+00
1.500000 1.00 1.000000 1 1 1.0000E+00 2.0000E+00
1.500000 1.00 1.000000 1 2 2.4617E-04 2.9833E+00
1.500000 1.00 1.000000 1 3 1.0000E-04 2.9833E+00c
2.500000 2.00 1.000000 1 1 1.0000E+00 2.9491E+00
2.500000 2.00 1.000000 1 2 2.2184E-04 2.9299E+00
2.500000 2.00 1.000000 1 3 1.0000E-04 2.9299E+00c
3.500000 3.00 1.000000 1 1 1.0000E+00 3.8564E+00
3.500000 3.00 1.000000 1 2 1.3769E-04 3.8343E+00
3.500000 3.00 1.000000 1 3 1.0000E-04 3.8343E+00c
4.500000 4.00 1.000000 1 1 1.0000E+00 4.7154E+00
4.500000 4.00 1.000000 1 2 3.6744E-05 4.6899E+00c
5.500000 5.00 1.000000 1 1 1.0000E+00 5.5186E+00
5.500000 5.00 1.000000 1 2 3.1679E-04 5.4890E+00
5.500000 5.00 1.000000 1 3 1.0000E-04 5.4890E+00c
6.500000 6.00 1.000000 1 1 1.0000E+00 6.2570E+00
6.500000 6.00 1.000000 1 2 6.6845E-04 6.2227E+00
6.500000 6.00 1.000000 1 3 1.0000E-04 6.2227E+00c
7.500000 7.00 1.000000 1 1 1.0000E+00 6.9203E+00
7.500000 7.00 1.000000 1 2 9.8359E-04 6.8805E+00
7.500000 7.00 1.000000 1 3 1.0000E-04 6.8805E+00c
Ok, but there's no way to make a graph of it vs. for example time in Algor?
What I do is to copy this column to MS excel and plot it over there.
