Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Bug Report: Custom Results
3 REPLIES 3
scudelari
382 Views, 3 Replies
Hello Everyone,
I would like to report a bug: One does not simply show custom results with Ribbon interface.
Version I am using: Mechanical 2013
Bug steps:
1- Create model.
2- Set up model.
3- Run simulation.
4- Create custom results using Ribbon.
5- Results Contours -> Other Results -> Custom Results -> Manager
6- It must be calculated, so re-run simulation.
7- Try to select custom result  Results Contours -> Other Results -> Custom Results -> Your result
8- Nothing happens.
9- Change UI to classic.
10- Results Menu -> Last line has your custom menu. Select it.
11- Voilà: Custom Resutls appear.
I understand that this is non critical and that there is a workaround for it, but this is quite annoying....
Thanks, and I hope I was helpful.
3 REPLIES 3
andrewdroth
in reply to: scudelari
It's still the same in Simulation Mechanical 2015.
I was told last year that it was a known issue.
If it's a known issue, why not fix it?
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
in reply to: andrewdroth
Bug fixes that you or I report may or may not be a high enough priority to be fixed. I also have submitted bugs that have been allegedly sent to "developers" and they are not fixed. Imagine all of the issues that have to be handled!
Sualp.Ozel
Thank you for reporting this bug. We are working on a fix for our upcoming release.
Sualp Ozel
Autodesk Simulation Mechanical Product Manager
