Hello all,
I am new to Algor and would like to know is how you go about defining surfaces for pressure loads on a complicated geometry in Algor. I would like to apply the load on only a portion of an existing surface on the part for example. Thanks in advance for any advice.
Andrew
Solved by S.LI. Go to Solution.
You can split the surface in CAD package, if it's from there.
Another way is to change line attributes.
1.) select all lines on the portion with surface loads;
2.) change their attributes to make a new surface.
