I have been trying to run CFD via Simulation Multiphysics for a few weeks now and cannot get around this error every time I use the program: (see attachment)
It works fine on my laptop, but I need more computing power so this question is in reference to my destop pc (specs attached below).
I figured it may be due to registry errors. I've tried reinstalling it multiple times, made sure my OS was updated. Any help on this would be appreciated. I will be able provide any additional information promptly.
Hi 758759,
Specifically when does the error occur? For example, does it occur as soon as the interface appears? Is it when you try to open a file? (If so, what type of file?) Is it when you try to create a new (blank) file? Is it at another time?
I guess that something messed up in registry for UI components.Do you have multiple ASIM version install, my suggestion is uninstalling and reinstall the product, and using SP may help.
Another better solution is manually modifying your windows registry, but it's risky.
I only have 2012 ASM installed. However, I did have older versions of inventor and various autodesk programs until I removed them. I just bought a new SSD and will be installing it soon. So, Ill have to reformate and reninstall anyways. If that doesnt fix the problem. I give up. I might have to use Solid works, as much as I don't want to, just to finish my analysis.
