Hi There
I have a client with a new PC with the following specs but keeps getting an error when running a simulation
The system specs are as follows:
Intel Core i7 2.7GHz
32GB Kingston DDR3 Memory
2x Intel 530 240GB SSD in a Stripe
2 x Western Digital 2TB in a Mirror
NVidia Quadro K4000
There is 65536MB of Virtual Memory allocated to each drive C: (SSD) 😧 (2TB) – There is 300GB Available on C: and 1.3TB available on 😧
When they try and run the simulation it gets to load case 1 and then stops and get the following error
Invoking Parallel BCSLIB-EXT Sparse Solver...
Begin solving nonlinear equations of load case 1
BCSLIB-EXT solver memory status:
in-core memory requirement (MB) = 0.00
minimum memory requirement (MB) = 9964.35
user specified memory (MB) = 17032.70
available physical memory (MB) = 17032.70
available virtual memory (MB) = 147828.36
memory currently allocated (MB) = 8192.00
Error: Required minimum memory exceeds 8 Gigabytes.
Reduce model size may solve this problem.
Error occurred with module: C:\Program Files\Autodesk\Simulation 2014\srunx.exe
this is becoming a bit of an issue and really need to sort any and all help would be appreciated
thanks in advance
