I have a compressor mounted on a S/M structure, that is expected to experience ~2 to 4 times the G force. Is there a way to apply this load on to S/M structure?
Currently, my analysis is set up with S/M structure and a node indicating the c.g. of the compressor. The node is connected to the sheet metal structure via remote load (weight of the compressor). The gravity is activing in -Y direction.
Jay
Autodesk Algor 2010
Solved by zhuangs. Go to Solution.
You can assign the G (gravity) force, and then set a load curve with a multiplier with a value of ~2 to 4 times, as you mentioned. In this case, the gravity of sheet metal part will also ~2 to 4 times, but it will be fine.
