Discussion Groups
Simulation Mechanical and Multiphysics
New Member
sdblacke
Applying Loads to A Beam
191 Views, 3 Replies
12-01-2013 07:17 PM
I'm working in Autodesk Simulation Mechanical and I have an I-beam which I'm constraining at the ends and applying a load (distributed and a point)  to the top surface of the beam. I only want to apply the distributed load from one edge up to a certain length of the top surface (not the entire surface) and the point load at any point on the surface. How do I go about doing this?
Thanks in advance.
Shawn
Please use plain text.
Product Support
KubliJ
Re: Applying Loads to A Beam
12-02-2013 10:45 AM in reply to: sdblacke
Hi Shawn,
How are you modeling the beam (what kind of elements are you using)? Are you using beam elements (lines), a solid representation of the beam (using brick elements), or a surface/midplane model (using plate elements)? Depending on which elements you are using, will have different answers.
James
James Kubli
Please marked this as solved if your question has been answered.
New Member
billah91
05-14-2014 07:29 PM in reply to: KubliJ
i used autodesk simulation student version.my problem is, how to create distributed load on the flat structure.in my case is pallet structure..i want to test on 10000N distributed load.
Thanks in advance.
bill lah
Valued Mentor
AstroJohnPE
05-16-2014 06:35 AM in reply to: billah91
After defining the element type to be beam, you select the lines that you want to load ("Selection > Select > Lines") and apply the load ("Setup > Beam Loads > Beam Distributed Load").
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
16 years experience with Simulation Mechanical
