I'm working in Autodesk Simulation Mechanical and I have an I-beam which I'm constraining at the ends and applying a load (distributed and a point) to the top surface of the beam. I only want to apply the distributed load from one edge up to a certain length of the top surface (not the entire surface) and the point load at any point on the surface. How do I go about doing this?
Thanks in advance.
Shawn
i used autodesk simulation student version.my problem is, how to create distributed load on the flat structure.in my case is pallet structure..i want to test on 10000N distributed load.
Thanks in advance.
bill lah
After defining the element type to be beam, you select the lines that you want to load ("Selection > Select > Lines") and apply the load ("Setup > Beam Loads > Beam Distributed Load").
