Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Algor vs cf design
2 REPLIES 2
Dan_Margulius
1005 Views, 2 Replies
Algor vs cf design
Hello guys ,
I dont know if this the right place but I would like to know wich program is better in electronic system analysis.
Thanks ,
Dan
2 REPLIES 2
Joey.X
in reply to: Dan_Margulius
ALGOR CFD:
Flexibility for importing CAD model and handmade structure mesh, apply BC either on surface or node; Fan models with fan curve, fluid reaction force output for structure analysis, flow rate check for mass conservation verification.
CFDesign:
Does not support manual structure modeling, no loads on nodes,  faster fluid /thermal coupling, more turbulence models
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
Dan_Margulius
in reply to: Joey.X
OK, Thanks
Dan
