Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Algor geometry move graphics "grey out"
8 REPLIES 8
Message 1 of 9
1157 Views, 8 Replies
When I add lines or use point move in Autodesk Algor Simulation, the lines drag around the screen, effectively greying out the surrounding area, making it difficult to see where a connect point is (see attached screenshot). Is this something I can fix with the graphics card or settings?
8 REPLIES 8
Message 2 of 9
I have the same problem. Also under retangular selection the area in the selection box gets greyed out.
MES Installed with SP1
Window Vista 64
Generic PnP Monitor
NVIDA GeForce 9800GT graphics card
Message 3 of 9
S.LI
unchecking OpenGL is helpful somtimes, which locates at options->Graphics->Hardware.
If this response answers your concern, please mark it as "solved".
Message 4 of 9
in reply to: S.LI
Thank you for the reply. I had tried that but the GL option is dimmed for me - I assume that means I don't have Open GL card and it is already turned off. See attached for detail. Is there something else I should try.
randy
Message 5 of 9
S.LI
According to my experience, "dimmed option" does NOT equal to "disable". Actually, this happened to my machine. I was not allowed to change it. But someday, it's changable.
I don't know why that's happened. it might be something in OS.
Message 6 of 9
Yes, I have the same "dimmed" enable Open GL command in the Hardware window as well,
Gyrus1
Message 7 of 9
jjs-autodesk
The hardware acceleration option requires administrative privileges to change on a computer.  If you do not have administrative privileges, it will be "dimmed" and unchangeable.
If the option is dimmed for an administrator, it is likely because you have no hardware acceleration capabilities; in that case it should also be checked.
From your screenshot, it appears you do have hardware acceleration available.  It also appears as if you do not have administrative privileges since the option is dimmed.
Joel Schultz
Principal Engineer
MFG-Digital Simulation
Joel Schultz
Principal Engineer
PDG-Simulation
Message 8 of 9
jjs-autodesk
A similar problem was reported here.  This is being looked at for an upcoming release.
Joel Schultz
Principal Engineer
Joel Schultz
Principal Engineer
PDG-Simulation
Message 9 of 9
Excellent! That cured the problem.
Thanks Group for your help,
Gyrus1
