Comments field for material properties window
Can a comment field in the material properties window? Many values are assumed because data sheets can be very vague. I would like an opportunity to save comments about the material they create and use. This helps with trace-ability for project requirements and helps improve data reliability.
2 Comments
dean.rose
babak.farrokh
I suggested the same when I met the team at CAMX in FL.
Babak
