Minimize input file modifications performed by xSTIFF
When xStiff is run, it significantly modifies the "layout" of the input file. For example, whitespace is deleted, letters are capilized, etc.
Ideally, xStiff would only add the stiffness parameters to the input file and the remaining bulk of the modified input file would be identical to the original input file.
2 Comments
dean.rose
 For example, discrete orientation definitions became invalid after running xStiff.
This issue has been resolved in version Autodesk Simulation Composite Analysis 2014
dean.rose
Status changed to: オートデスク審査落選
