Dear All
Installed Autodesk composite analysis 2015 to work with Abaqus 6.131. Previously, I have no problems in running in Abaqus 6.131.
But when running any input file from GUI after the installtion, it just aborts with the following errors:
Abaqus Error: The executable standard.exe
aborted with system error code 1073741819.
Please check the .dat, .msg, and .sta files for error messages if the files
exist. If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and
save your system information. Use the same command to run Abaqus that you
used when the problem occurred. Please contact your local Abaqus support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
Abaqus/Analysis exited with errors
Looking forward to the advice, if any.
thanks
