Hello
Who have any examples with two-phase flow.
Can I do analysis of this type in CFD?
Best regards,
Anton
Solved by Jon.Wilde. Go to Solution.
Hi Anton,
Presently, no we cannot run 2 phase flow. We can run scalar models showing diffusion between 2 similar gases, smoke in air for instance.
Is the application totally 2 phase?
Kind regards,
Jon
Jon
I would like to calculate the velocity distribution in the flow of oil in a steady volume of air
is it possible?
Anton
Hi Anton,
Your closest option would be to run with just air. You could use massed particles to study where oil would be carried to within this but that is as far as we could really go.
Hi Anton,
Yes, we cannot have such radically different fluids mixing in CFD. The only solution would be to use massed particles but this is post processed and not true mixing.
