Can we do simulation of missiles in autodesk simulation cfd 2013 so that all cases are considered?
Solved by Royce_adsk. Go to Solution.
We are going to need more detail on what you are trying to do.
Royce
taking other parameters as constant and changing only the nose shape of missile i want to know the change in drag coefficient,pressure at tip ,temperature profile and everything related to cfd. can i do that in this ?
What do you expect the speed of the missle to be?
the speed of missile may be around 600 m/s
can i get the temperature profile at the nose assuming air as compressible?
Yes. Please review the compressibility documentation:
-Royce
