CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
simulation cfd 2013 result problem
23 REPLIES 23
Message 1 of 24
mili5500
933 Views, 23 Replies
i read every toturials about thermal comfort
i model a room with an occupant,i tried to inter a 0.1 m/s velocity to the room with boundry condition on window
the first few times i get the result but now it show temperature without change inside of the room and the plane result doesnt work anymore,i tried to reinstall it but nothing happend,i really need help bcuz i need those result for my thesis
23 REPLIES 23
Message 21 of 24
mili5500
in reply to: Jon.Wilde
my model is 4 X 4 x 4 meter,that was my hypothesis
Milad
Message 22 of 24
Jon.Wilde
in reply to: mili5500
Hopefully you have this sorted now. I cannot really make anything out regarding meshing.
I would take a look at it as shaded (not wireframe). 2 elements through the walls is a minimum.
Also add a cut-plane and take a look at the mesh there (show cut-plane as shaded by mesh).
Please let us know if this is now working OK.
Jon
Message 23 of 24
mili5500
but this model is 10 by 10 and 4 meters in height
Message 24 of 24
Jon.Wilde
OK, that is fine. Changing it to mm, will give you 4000mm height, spot on.
Right now your model is 4km high. Check the units within CFD, perhaps they are not set the same as your CAD system. Typically this does not happen but I have seen it before.
Jon
