after autosize mesh and then continue to solve, suddenly appear this pop up, anyone can solve this problem
so i can't see the plot of iteration and result
a lot of thanks if can solving this problem
*forget : i get this problem on Autodesk Simulation CFD 2013
Did this message only recently start popping up?
Royce
i have solve this problem after browsing a many source, this problem appear when install a new software (anything software) not only from autodesk, i think this problem related with the OS
thxx..
Uninstall the software and reinstall. When you go to reinstall choose 'run as administrator' from the right click menu instead of just running the setup executable. This may fix the issue.
Royce
