Discussion Groups
Simulation CFD
Active Contributor
pei-ying.hsieh
Accepted Solution
plot temperature on a location (given x,y,z)?
184 Views, 3 Replies
08-22-2013 06:57 AM
Dear Simulation CFD experts,
I did a transient conjugate heat transfer case.  Is there a way to plot (or store) the temperature as a function of time on a set of locations (say given a set of x,y,z)?  The locations might be in air domain or solid.
Thanks!
Pei-Ying
Please use plain text.
Product Support
Royce_adsk
Re: plot temperature on a location (given x,y,z)?
08-22-2013 04:00 PM in reply to: pei-ying.hsieh
Hi Pei-Ying,
You are going to want to look into reading about monitor points:
http://wikihelp.autodesk.com/Simulation_CFD/enu/2014/Help/0532-User_s_G532/0698-Process698/0836-Solv...
Royce Abel
Active Contributor
pei-ying.hsieh
08-23-2013 07:25 AM in reply to: Royce_adsk
Thanks Royce!
Pei-Ying
Active Contributor
pei-ying.hsieh
03-10-2014 05:35 PM in reply to: Royce_adsk
Hi, Royce,
The monitoring point can be used prior to start running the case.  How about the calculations have been completed.  Say, I save results every 10 min and the case is a 2-hour case.  How to plot (or save) the temperature at a specific location as a function of time?
Pei-Ying
