For closed channel flow, how are inlets and outlets assigned? Is this just through BCs for either velocity/flow at one end and pressure at the other?
Solved by Jon.Wilde. Go to Solution.
Exactly that. yes. Avoid assigning a flow rate and pressure to the same surface, flow rate one end and pressure the other.
