Discussion Groups
Simulation CFD
New Member
albatross918
how can i set rotor?
81 Views, 1 Replies
11-25-2013 05:11 AM
well....i sim the rotor( use motion angular, rotating regions = rpm 20000)
boundary conditions
 pipe = air
 rotor, stator = steel
 inlet,outlet = 0pa or inlet 500m/s outlet 0pa
 motion or rotating regions = 20000rpm
but it doesn't flow, like that image
Wind is always a turn around an object, Not the wind blow back
how can i set this rotor? using periodic bounary contions? but i can't set that
pls check this
http://www.youtube.com/watch?v=IqAEs4s17Hs
http://www.youtube.com/watch?v=Lkf9y76E1TY
Please use plain text.
Product Support
wildej
Re: how can i set rotor?
11-25-2013 08:32 AM in reply to: albatross918
In the first instance, you have no inlet duct.
I suggest you might like to read this guide on how best to approach these types of models.
Kind regards,
Jon
Jon Wilde
