CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
distributed resistance
7 REPLIES 7
Message 1 of 8
pei-ying.hsieh
944 Views, 7 Replies
Dear Autodesk Simulation CFD experts,
I would like to model a thin plate with a bank of holes.  The thickness of the plate is 2 mm.  The diamter of the holes is 1.5 mm.  The distance between each 2 hole center is 4.8 mm.  It looks like I can use the K-Factor method.  But, how can I find out the K value?  Or is there any other method in CFD 2014 that will be more suited for this?
Thanks!
Pei-Ying
7 REPLIES 7
Message 2 of 8
To start you might look at the geometry and compute the Free Area Ratio
You could use this as input to the resistance model.
If you want to compute to a K the equation that would be used is
K = ( [0.707(1-FAR)^0.375 + 1 - FAR]^2 ) / FAR^2
Message 3 of 8
Hi, Apolo,
Thanks again for the reply!
So, for a 5X5 holes:
     Total area = 24mm X 24 mm = 576 mm^2
     Free Area = pi x (1.5 mm)^2 x 25 /4 = 44.18 mm^2
==> FAR = 44.18/576 = 0.0767
Correct?
However, based on the wikihelp docuement,
The relationship between loss coefficient, K, and free area ratio, FAR, is given as:
NoteThis equation is valid for flow with Reynolds number greater than 105. The ratio of the flat portion of the hole length, l, to hydraulic diameter, Dh, is between 0 and 0.015:
Dh = 1.5 mm, plate thickness = 2mm, hence, I/Dh = 2/1.5 = 1.33.  Does this relationship still applies?  In addition, the note mentioned that this relation is valid for Re > 10e5 (or 105?).  I believe that in my case, Re is < 10e5.
Pei-Ying
Message 4 of 8
OmkarJ
in reply to: pei-ying.hsieh
pei-ying
You are right, the formula Apolo mentioned is for very thin sheets (t/d<0.015). Yours is a thick sheet and hence the formula will be different,
You can get the constant k-factor by two methods:
1) Use Idelchik's handbook of hydraulic resistance to find the k-factor for your perforated sheet
2) Create a small unitary cell that is symmetrical, and simulate it for velocities, close to your operating velocities, and then calculate the value of k as : k=DP/ (0.5*rho*v^2)
where DP is pressure drop, rho is density of fluid and v is velocity.
OJ
Message 5 of 8
pei-ying.hsieh
in reply to: OmkarJ
Hi, OJ,
Thanks a lot!
I am in the process of getting the handbook.  In the meantime, I will try to do what you suggested in option 2.
Pei-Ying
Message 6 of 8
sanket.p
Hello Pei-Ying,
It was informative to read your post. As the post is quite old, could you please share your experience with simulating perforated sheets using Sim CFD because I am also working with a similar application and it seems that using the FAR condition isn't sufficient.
Sanket
Message 7 of 8
Jon.Wilde
in reply to: sanket.p
Hey Sanket,
(Yup, I am everywhere Smiley Happy)
If you run into other issues, please shout, we can help.
CFD will convert everything to a constant loss coefficient for the calculation, but FAR should be OK as long as you are smart with it.
Jon
Message 8 of 8
sanket.p
in reply to: Jon.Wilde
Hello Jon,
Thanks for your reply. I was only wondering if Pei-Ying tried the 2 suggestions given by Omkar and how did they influence his results...
Sanket
