Discussion Groups
Simulation CFD
brian
cfd 2013 crashes on startup
1174 Views, 9 Replies
06-21-2012 09:17 AM
We are running cfd 2013 on 4 computers.  One is having a problem. On startup after the splash screen I get the following message "autodesk simulations cfd 2013 has stopped working".  I have uninstalled and reinstalled the software.  Still get the same error.  Is there a log I need to look at or system processes I need to check.
win 7 x64
Thanks for the help
Brian Brisbin
National K Works Inc.
Please use plain text.
brian
Re: cfd 2013 crashes on startup
06-22-2012 06:17 AM in reply to: brian
We solved it.  It turns out to be a know issue.  "tabletinputservices"
Thanks.
Brian
Product Support
Royce_adsk
07-19-2012 09:23 AM in reply to: brian
For more information regarding this issue:
http://upandready.typepad.com/up_and_ready/2012/06/autodesk-simulation-cfd-2013-crashes-at-startup.h...
Also make sure that 'TabletInputService' or 'Tablet PC Input Service' is disabled in your services list in Windows.
-Royce
Royce Abel
New Member
m.habr
07-31-2012 03:05 AM in reply to: Royce_adsk
I have got a problem with Autodesk SImulation CFD - I have installed it. When I firstly run the program, it requested code and serial, which I have inserted. Then an error appeared - The program stopped working. I have Windows 7 (64bit).
I  dont have on-screen keyboard. Service 'TabletInputService' is stopped.
Do you know what should fix this?
Thank you!
ghmail16
08-24-2012 04:16 AM in reply to: m.habr
I have also disabled TableInputServices from Services List but the problem of startup remains?
What is the solution?
Thanks!
Product Support
Royce_adsk
08-31-2012 08:11 AM in reply to: ghmail16
ghmail16
09-01-2012 02:48 AM in reply to: brian
Unfortunately I still have the same problem. I attach a picture to show you what is the message that I get when I try to open it. It is not the same that shows in the page that you cite me.
Thanks Again.
Best Regards!
New Member
Zh4x0r
10-05-2012 01:30 PM in reply to: ghmail16
What about those of us that need to have the Tablet PC Input Service running?
I have a touch-screen computer that I use for design, and enabling/disabling the Tablet service every time I need to run the simulation is going to get very old, very fast.
Product Support
Royce_adsk
10-05-2012 02:58 PM in reply to: Zh4x0r
Please checkout SP1.  That should fix the issue.
Thanks!
Royce
Royce Abel
ghmail16
10-06-2012 01:50 AM in reply to: Royce_adsk
My issue was that I was not opening the programm as administrator. When I run it as administrator it opened normally. :-)
