Hi i have a model need use free surface and make like sea wave
and i know how to setting the free surface and my problem is how can I make the wave
THX
P.S if necessary I can upload my model thanks a lot
Solved by waited. Go to Solution.
When a velocity boundary condition is a harmonic function of time, the describing equation is,
F(t) = A1 * cos( B1 * t + C1 ) + A2 * sin( B2 * t + C2 )
Typically I use just the cosine part of the equation, so A2, B2, and C2 are zero.
A1 = controls the amplitude of the wave
B1 = controls the wave period
C1 = control wave shift, but usually I set this to zero.
The BC is applied to a vertical surface and the insurge and outsurge of water causes the wave motion.
Dave
The wave needs to be contained. Typically the water is placed in a container like a wave tank. The harmonic velocity boundary condition is applied on the left end. An air region need to be meshed above the water free surface so that the waves can lift and drop. If you model a beach area, you can model it as shown in the attached image. Harmonic velocity boundary condition on the left, air region above the water. Beach surface rising up as you look to the right.
Dave
thank you for your replying
when I see your solution I have some question
1. The CFD is no support air mix water , so I don't know how do you do that
2. how do you setting about your motion.
Is it setting free motion ?
and how can I do the same motion with you
3.I made a model is floating in the sea , but the motion is obsession to settting
so ,how can I solve the problem the motion it's move and shake
my model like this picture
For free surface analysis, you need to mesh any area where the water might go. Elements are either filled, part-filled or empty. We consider the elements that are empty to be air, but we don't explicitly model air properties there. Instead, we set a reference pressure there ( 0 psi gage ) on the free surface.
Yes the object is a free motion part. You can use the motion dialog to assign it as free motion, define a gravity vector, and set the allowed degrees of freedom you want to consider ( probably all 6 for a 3-D problem ).
Free surface problems and motion problems require a very fine mesh to capture the wave physics interacting with the motion part. You will need millions of element in the area where the floating object is sitting in the waves. This is much easier to do in 2-D.
Dave
this in my new project
I follow your direction and make a new model
but the motion I still can't let it to the same move like yours
can you help me more clearly
like free motion and how is the setting
by the way
I find a problem
if my motion is made for two part
and I set them a group , then the mesh I inhibit
because they all are solid and setting free motion ,but the results the group is no motion
another setting is two part is a group and no inhibit to free motion
the results is the group will have differen motion
why ?
the pic is my new project and the cfz , I don't know whhy only straight line motion and no free motion
which place is wrong
The parameters used in the harmonic velocity function should be chosen such that they represent the expected wave frequency. Using B = 3 means that the wave period is 2 pi / 3 = 2.09 secoonds which is too quick for waves on this scale. When you run this, the free surface essentially shows small ripples.
I made a few changes to the cfz file data:
A = 5 ( stays the same )
B = 0.6283 ( corresponds to a period of 10 seconds )
C = 0 ( no phase shift is required.
time step size = 0.01 seconds. Fairly large waves result ( see attached images ). To reduce the amplitude of the waves reduce the value of A from 5 to something smaller ( say A = 2 ).
Dave
Thank you solve the wave's question
but I have another prooblem is about two part set a group
I want the two part setting a group and do the same motion
but they can't .
Why ?
and I try two way on the mesh
one is the mesh no inhibit but the motion isn't I want
the other is the mesh inhibit and the motion isn't effect
can you help me thank you
and this my data
Hi Dove
I have a question want to solve, but I can't make by myself.
Here have a pic in attached file
in the pic there have two red rectangles
I want set two red rectangles to a groups and do the same motion
I try to setting them a groups ,but the motion is different
Can you teach me how to set the config
Thanks for your help !
I was not able to get multiple free motion parts linked by a motion group to move in harmony together. For now, I would suggest that you restrict your floating bodies to be composed of just one part.
Dave.
OK Thank you
by the way
what is the difference in groups dialog
groups type "Geometric" and "Motion"
have some difference ?
Thank you !
Can you please upload the support file of the problem you solved?
There's the attachment of your solved problem picture! support file would be helpful to understand setup! thanks you 🙂
Geometric groups associate parts or surfaces using a group name. This name can be referenced when assigning properties or boundary conditions. This can be convenient when there are many items in a group.
A motion group is a special group type that associates the same motion parameters to all parts in the group.
Dave
