I load an old *.cfdst file and I run for some iterations. When the code has finished iterating I can run for some more iterations with no problems. So far, so good.
However, I bump into problems when doing the following:
1) Load already solved *.cfdst file (let's say this case ran for 500 iterations)
2) Run for another 10 iterations
3) Exit the software without saving (note I do not exit until I see the message "Analysis completed successfully" in the output window
4) Open Autodesk Sim CFD again and load the previous .cdfst file >> First question: The file is at 510 iterations. How is that? I exited without saving... didn't I?
5) Try to run for some iteraitons >> The SOLVE button under the Solve panel says STOP, instead (why? I never started running it). On top of that, when I hit the STOP button, all I can read is "User stop request sent to server" and it stays this way forever
Any thoughts?
Your help will be much appreciated
Solved by Dan_Margulius. Go to Solution.
