CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Water hammer
3 REPLIES 3
sirkoattila
633 Views, 3 Replies
Water hammer
Hello!
I try to simulate water hammer in pipeline with two valves. The simulation works fine if both of the valves close at the 0 time step, but i have e.g 20ms time difference between the closes(now we don't care about the closing velocity, it's infinitly fast). So somehow i have to define this delay between them.
I've tried to do this with use the time curves when i define the transient boudary condition. The defined value doesen't follow the function what i gave.
My system looks like this:
Valve 1 closes at 0 s.
Valve 2 closes 20ms later, the predifed velocity-time curve:
The velocity change at valve 1:
The velocity change at valve 2:
As you can see, the closure happens at the same time, no matter what i defined earlier.
Please give me ideas how can i implement/simulate this 20 ms delay!
Thanks a lot!
Attila
3 REPLIES 3
sirkoattila
in reply to: sirkoattila
Finaly solved.
after SS run->giving the valve1 closing TR boundari condition->transient run from 0s to 20ms->giving the valve2 closing TR boundari condition->continue transient run as long as you want
hbaroki
Hello sirkoattila and everyone who can help me.
You said that "giving the valve1 closing TR boundari condition" Which boundary condition must I choose to give closing valve?
Thank you all.
Jon.Wilde
in reply to: hbaroki
I would say, velocity = 0, is really the only way.
This is all a good suggestion for the Idea Station
