Discussion Groups
Simulation CFD
Valued Contributor
pompeo79
Water Column, Static Pressure Study
189 Views, 11 Replies
05-13-2013 04:25 AM
Hi to all,
here a video i made  to describe it for you (static pressure in a 10 m water column)
http://www.youtube.com/watch?v=oTjWx3MnHsc
Where i wrong?
Thanks for suppport,
Pompeo
Please use plain text.
*Expert Elite*
OmkarJ
Re: Water Column, Static Pressure Study
05-13-2013 11:55 AM in reply to: pompeo79
Video is not available!
OJ
Valued Contributor
pompeo79
05-13-2013 01:37 PM in reply to: pompeo79
The video works fine now. I think it was a youtube issue.
Tell me if it's ok for you guys too.
Valued Contributor
pompeo79
05-14-2013 02:35 AM in reply to: pompeo79
If the previous video won't work, try with this one, more stable:
http://www.youtube.com/watch?v=i8j3b3fOu-8
Valued Contributor
pompeo79
05-14-2013 06:47 AM in reply to: pompeo79
The pressure at the bottom of a 10 m water column would be 100 Kpa
With the simulation i obtain 164 Pa for the bottom of the column.
Any ideas?
For considering gravity force i have set : SOLVE > Physics>Heat Transfer>Gravity Direction 0,0,1
Active Member
mrnfs
05-14-2013 09:36 PM in reply to: pompeo79
Try ... Gravity Direction 0,0,-1
Valued Contributor
pompeo79
05-15-2013 01:08 AM in reply to: pompeo79
same distribuition..but reversed...same maximum of 164 Pa.
Valued Contributor
pompeo79
05-17-2013 05:31 AM in reply to: pompeo79
No one?
In other word...is it possibile with cfd simulation do a hydrostatic study of pressures in a simple water column?!
Product Support
Royce_adsk
05-17-2013 06:14 AM in reply to: pompeo79
The quick answer to that is that we aren't traditinally setup to do hydrostatics.  When we introduced the free surface modeling in 2014, that does include hydrostatics so you could try using that.
Also, try turning on the total pressure result, I think that does give you the hydrostatic pressure result.
-Royce
Royce Abel
*Expert Elite*
OmkarJ
05-17-2013 07:57 AM in reply to: pompeo79
I have a bad experience with hydrostatic flows, at least for SimCFD 2013. But for some reason, I believe that this dodgyness in results is our inability to set the right boundary condition for top surface of the water column.
I hope that 2014, with the free surface BC, the top surface has now an adequate representation, and will come down in a more natural and realistic manner, as the water in the column is released from the bottom. This doesn't happen now with 2013 and perhaps solver struggles to find peace with the mass conservation.
OJ
