Discussion Groups
Simulation CFD
Member
ffxue
Unable to apply the resistance material
105 Views, 2 Replies
06-27-2013 01:27 AM
Hello everybody
I have a problem to apply the resistance material.
I followed the instruction to simulate the HVAC system example in the CFD2013 software, but when I finished all the setting then to click the apply button, the material box is not disappeared. In order to simplify this issue, I only apply the resistance to the rectangular plate, the problem still existed. I used the V10 version before, it never happened, now in the 2013 version, I don't know why I can't apply the resistance material?
Please use plain text.
Distinguished Contributor
ilyas
Re: Unable to apply the resistance material
06-27-2013 02:07 AM in reply to: ffxue
You need to set your fluid material first before setting your resistance material.
Member
ffxue
06-27-2013 06:07 PM in reply to: ilyas
Yes, thank you. In V10, all the parts were set air as default, but in 2013, all are unassigned. This is the big difference. Appreciate your reminder.
