CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Turbulence settings
1 REPLY 1
428 Views, 1 Reply
Turbulence settings
With Autodesk SIM Pro (multiphysics) the "easy" turbulence model is LES (large eddy simulation). What is the equivalent in CFD 360 that makes convergence easier and less computational expensive? I am not seeing that as an option.
1 REPLY 1
Jon.Wilde
Hi jrm,
Best to leave the defaults on, rather than make changes to turbulence settings, there are not really any shortcuts here. We change them depending on the model type that is being solved, to improve accuracy. Convergence should not usually be a challenge with the correct settings.
