Discussion Groups
Simulation CFD
Accepted Solution
The solar heating value at different area in CFdesign
153 Views, 3 Replies
09-10-2013 02:23 AM
I want to do comparison with the simulation and experimental results.
But how can I know the value of solar radiation at different area in CFdesign to ensure the simulation and experimental conditions is consistent. Thanks very much.
Please use plain text.
Product Support
Royce_adsk
Re: The solar heating value at different area in CFdesign
09-13-2013 06:05 PM in reply to: amy.jin
Hi Amy,
Are you looking to see what the solar heat flux is for your analysis? There is a setting we can adjust for the max solar heat flux, but you can just look at the global heat flux result quantitiy to see what head flux is being applied based on time and location.
Royce Abel
10-11-2013 11:42 PM in reply to: amy.jin
Hi Royce,
Thanks for your reply.
I really want to see what the solar heat flux is for the analysis.
How can I set to adjust for the max solar heat flux?
Thanks.
Product Support
Royce_adsk
10-15-2013 12:41 PM in reply to: amy.jin
Hi Amy,
Refer to this flag to adjust the max solar heat flux.
http://help.autodesk.com/cloudhelp/2014/ENU/SimCFD/files/GUID-E5A7D386-6484-4ABB-95E2-C64049301343.h...
Thanks!
Royce Abel
