CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
TecPlot export doesn't work
3 REPLIES 3
RAALVM
853 Views, 3 Replies
Hi I want to export the results as a TecPlot file, I keep pressing the export button but I do not get a dialog where to save the file and the Simulation CFD shows in the status bar (at the botton) an export message, and after that nothing, I can't find the file in any of the simulation folders.
I have the latest Autodesk Simulation CFD 360 installed on the system.
P.S.: the same is happening if I want to export to FieldView.
Please Advise
3 REPLIES 3
apolo_vanderberg
in reply to: RAALVM
Typically this will get exported to the Solver directory of the active scenario.
You'll also see *.xfr files that if opened in notepad will give you information about our export process, such as if there were any issues during the export. Some of these messages also gets put in to the status file (*.st)
RAALVM
in reply to: apolo_vanderberg
Thanks, I have found the export files.
dharmon
in reply to: RAALVM
Have you now been able to import these files into Fieldview?  I have not been able to use the files I export form Autodesk CFD in Fieldview.  I was able to import a very small model that I made of a pipe tee.  However, whenever I try to inport larger files I get an error message that says ...ERROR - line NNNNNNN - char4:Expecting variable value
