Hi When I switch to plane results in CFD 360 2014 I get some strange patterns on the plane which are annoyng. Please take a look at the picture attached.
When I switch to global view these patterns desapear, also when I save to the file the patterns disapear
My system is an Aspire 7750G with AMD Raedon HD 7670M graphics card
Solved by OmkarJ. Go to Solution.
It is a kind of bug I guess. You can remove it by moving the plane slightly and bringing it back to its position. But the best remedy is to disable this:
Results >> Planes >> Planes drop down >> Plane outlines
This should make the the strange mosaic disapper.
I agree, this is a long-standing and rather frustrating bug. It is hard to predict when it will happen. I wonder if it only appears for certain graphics setups, or certain mesh situations, because I think it would be high on the list of things to be addressed if everyone had this issue.
I would very much like to see this addressed so that we can leave the plane outlines on but still get decent images consistently.
This happens on nearly every geometry regardless of the quality of the mesh. I do notice, that when the plane outlines are deselected that there are empty voids/white spots in my cut plane. I am not so sure this is a bug. Could it be poor mesh showing up in these regions?
