CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Steady state 1D heat transfer boundary condition
6 REPLIES 6
sabbir19me
732 Views, 6 Replies
It's a hollow cylinder having inner and outer radius a & b respectively.At the inner surface there is a heat source which is generating heat at a rate of 10^5 W/m2.The outer surface is dissipating heat into a fluid(having temp 100C) by convection.Convective heat transfer coefficient is h=400 W/(m2*C).I need to determine inner and outer surfaces temp.Need help applying Convective heat transfer coefficient is h=400 as boundary condition.
Sabbir
6 REPLIES 6
Jon.Wilde
in reply to: sabbir19me
It sounds like you need a surface heat flux on the internal surface and a film coefficient on the outer?
sabbir19me
in reply to: Jon.Wilde
Yeah.It's more like it.But if i apply film coefficient on the outer
surface,then what would be the proper value.The surrounding temp is
100C.Thanks for your reply.
Sabbir.
Jon.Wilde
Looking at your first post, would it not be 400 W/m2/K at 100C?
Jon
sabbir19me
As far as I know,it will be W/(m2*C) or W/(m2*K).
Sabbir
hs.simanto
Hi Sabbir!!!
You should apply a film co-efficient boundary condition to the outer surface of the cylinder. A heat generation BC in the inner surface of the cylinder. Only then you can measure your required outer surface temperature at steady state or transient state 🙂
Thank You!
Simanto
paul.bunuan
in reply to: hs.simanto
If you know what the total area of the inner cylinder is, couldn't you calculate the total heat generation (i.e., W/m^2 * m^2). There is an option to select total heat generation as a BC.
