Discussion Groups
Simulation CFD
Active Contributor
Accepted Solution
Sketches for 2D CFD
248 Views, 3 Replies
01-28-2013 03:37 PM
How does one get an Inventor sketch into Trial CFD Simulation? I have tried each origin plane. I have tried a simple rectangle and a simple rectangle with a circle inside. I keep getting an error message. I am assuming 2D sketches are used for 2D simulations. Is that assumption incorrect? Is there something in the help files about 2D CFD? This has been a show stopper for a week.
Please use plain text.
*Expert Elite*
Re: Sketches for 2D CFD
01-29-2013 05:38 AM in reply to: L103i050S
Why would you need to get a 2D sketch in SimCFD? Do you mean 2D mesh?
1) Just finish the sketch (say circle, square etc.)
2) "Patch" the required sections to create the surface. You can select the patch command under Model tab
3) Launch it to SimCFD
OJ
Active Contributor
01-29-2013 03:20 PM in reply to: OmkarJ
I didn't know about needing to patch the sketch. Things are working now.
Product Support
apolo.vanderberg
02-04-2013 09:20 AM in reply to: L103i050S
As Omkar mentioned for 2D models to come in to SimCFD they must be planar surfaces (on the XY plane).
Once you're done with the sketch you can do a Boundary Patch or fill it as you see fit.
A sketch alone is not sufficient to go in to Simulation CFD and setup a model.
Apolo
