Hello, very interested in the transfer of the building model from Revit 2013 to purge Simulation CFD 2013
Here describes how to configure a connection
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19973972&linkID=18154757
but unfortunately in the path C: \ Program Files \ Autodesk \ Simulation CFD 2013 \ Launchers \ Revit file with no *****.addin
Trying to write myself a notebook but does not work.
Question to the developers where to get the file with the transfer of Revit
If someone is not difficult to lay out the file extension *.addin, which is necessary to add or say, please remember that you need a file, I'll do.
<?xml version="1.0" encoding="utf-8"?>
<RevitAddIns>
<AddIn Type="Application">
<Name>Revit to CFD</Name>
<Assembly>C:\Program Files\Autodesk\Simulation CFD 2013\Launchers\Revit\*************.dll</Assembly>
<AddInId>0b6b55f0-1e44-4626-9bff-6a412e0dcd77</AddInId>
<FullClassName>**************.Application</FullClassName>
<VendorId>*********</VendorId>
<VendorDescription>Autodesk, www.autodesk.com</VendorDescription>
</AddIn>
</RevitAddIns>
