Discussion Groups
Simulation CFD
Active Member
Revit architecture 2012 CFD 2012
243 Views, 2 Replies
04-03-2012 11:07 AM
I have both Revit Architecture 2012 and CFD 2012,
I first installed the CFD 2012 and then Revit Architecture 2012.
however the add in for CFD 2012 appeared not in revit architecturesuite 2012.
what is the cause and what can I do?
Or is there another way to get a file from Revit Architecture in CFD 2012?
Please use plain text.
Product Support
Royce_adsk
Re: Revit architecture 2012 CFD 2012
04-10-2012 01:52 PM in reply to: markkolk
When installing your CAD package after you installed CFD, you will need to run the program CFDconfig.exe.  This is located in your install directory and should setup new CAD tools to work with CFD.
-Royce
Royce Abel
Active Member
04-11-2012 12:52 PM in reply to: markkolk
It works thank you
