CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Reusing adapted mesh
4 REPLIES 4
529 Views, 4 Replies
Hi what it is the best practices to reuse an adapted mesh?
For example let's presume I have runed an adaptive mesh and I have 3 meshes with the 4 th being the first scenario.
Now I want to use the 3 rd mesh for running multiple design and different inlet conditions.
Is this as simple as cloning the scenario and design?
thanks
4 REPLIES 4
OmkarJ
in reply to: OmkarJ
thanks! I presumed that will be the case. The problem is that if you run the new scenario form iteration 0 then your mesh isn't saved, it should be runed for s0 I think.
OmkarJ
When you clone the scenario, there is never an option as "s0" for the first time when you are meshing. It is either 0 or sXXX iterations. When you run it from 0 iterations, all the results of original scenario are wiped from the mesh and only boundary conditions remain. If you run it from sXXX iterations, where XXX is the number of iterations in original scenario, then the results of XXXth iterations get mapped on the mesh. You may have multiple sXXX options if you have saved the results intermittently in original scennario. Once you have created the mesh using either option, only then you have an option to run it from 0 or s0 iteration, and both yield technically the same result.
In all cases, mesh distribution is conserved, just the mapping of results is different.
in reply to: OmkarJ
ok thanks
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
