How to get Residual data from simulation resultat?
Solved by OmkarJ. Go to Solution.
When you look at the convergence plots, at the right hand side you have tabs labeled Global, All, Avg etc. Click on Avg, you will have then the option to view "Resid In" and "Resid Out".
OJ
Hi OJ
Can see this plot and when I save it is not any value of "Resid Out" ?
Can you explain me more precise how to catch "Resid Out " value ?
Regards
Sveinn
The resid out value per se may not be too useful since it is not normalised one (like other CFD codes, eg FLUENT, CFX etc). Rather, the ratio of resid in and resid out provides more insight into convergence.
Have a look at following thread where it is discussed.
http://forums.autodesk.com/t5/Autodesk-Simulation-CFD/CONVERGENCE-CRITERIA/m-p/3721810#M1129
OJ
