CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Regional Reynolds Number
4 REPLIES 4
453 Views, 4 Replies
Is there a way to look up the Reynolds number(s) in certain areas? For example, after finishing the simulation for the pump, say, I want to look up the Re around the impeller (I do know that Summary shows the Re for the inlet and outlet though). Is there a way to check the Re for the area?
Thanks in advance.
Joe
4 REPLIES 4
esmaeilk
Have you tried the wall calculator in the results tab? you can select the surfaces and get their stats in total and individually.
in reply to: esmaeilk
there's no such result quantity since the Re number always needs a definition of a typical length and velocity which a software of course cannot create automatically (aside from some basic assumptions for in- and outlets).
That's right. I figured. Thanks.
OmkarJ
There is a practice to recognize the Peclet number at the local cell to be called as local Reynolds number, since its definition (the ratio of advective to diffusive rate) is close to the definition of Reynolds number (ratio of inertial to viscous force). However, I do not think there is a way to access the local lengthscales and velocity scales (at the cell level) to evaluate the cell Peclet number. This can be particularly useful when you are studying the intermittancy in some areas where it is uncertain if the fluid is turbulent or laminar.
