I would like to ask for help for simulating the pressure drop for our product ball joint. The inlet pressure will be 10 bar, the incompressible fluid will be water. I would like to know what will be the output pressure or the pressure drop and how to set it up properly. Thank you in advance.
Solved by Royce_adsk. Go to Solution.
Solved by Jon.Wilde. Go to Solution.
You have a few options:
Dear Sir Jon,
I really appreciate your help, but I have another question why the area of inlet and outlet is changing?
I've used the option 1. Pls. find the attached file.
Thank you very much in advance.
Bjorn Fejer
Hi Bjorn,
For the opposite end, did you rotate the cut-plane so that it was in-line with the axis?
Hi Sir John,
Yes it was normal to it. But why is area changing? What is the cause of that? Thank you very much.
I will attached the fusion file, and it will be highly appreciated if you will have a try simulating.
Parameters is as follow:
Inlet Pressure: 10 Bar
Outlet velocity: 6 m/s
Bjorn Fejer
Hi Bjorn,
The area could be a function of your mesh quality. If you add more mesh to your analysis does that improve the correlation of your area between the 2 models?
-Royce
