Discussion Groups
Simulation CFD
Active Member
Possible Heat-Distribution in Inventor 2013
463 Views, 9 Replies
07-18-2012 11:04 AM
Hello
I am constructing a head of a flashlight and would like to know whether it is possible to use Inventor 2013 to simulate the head distribution in the aluminium Body for a punctual headsource (LED).
I am very new to this program and this forum, so iam not sure if i am in the right forum.
Thank you for your help!
Regards Max
Please use plain text.
Re: Possible Heat-Distribution in Inventor 2013
07-18-2012 11:37 AM in reply to: maxluedemann
Hi Max,
you may want to follow this link i guess it will shed some light on your problem.
regards
Matthias
Nihil Ex Nihilo
Active Member
07-18-2012 12:17 PM in reply to: maxluedemann
ah thx.
I am trying to follow the guide (i will reinstall in english later -.-) but i do have a problem with the choice of the material, do i have to install an additional app tu use it?
I installed Sim CFD EnergyBalance, but stil have not been able to find the right materials :smileysad:
Active Member
07-18-2012 06:43 PM in reply to: maxluedemann
Ok, I now found the LED-Finish in the Autocad Database, but this just seems to be some kind of "finish" not an actual "material" which I can use for the simulation?
Does anybody has an idea what might be the problem?
Regards
Max
Employee
07-18-2012 07:21 PM in reply to: maxluedemann
Can you clarify what software is being discussed?
  • Max mentioned Inventor, but I did not think that Inventor had the capability to simulate heat transfer (that is, heat distribution).
  • Matthias referenced a page from the Simulation CFD documentation, but Simulation CFD is separate software from Inventor.
It is close to my bedtime, so maybe I am just not reading, thinking, or understanding the discussion properly.
Sincerely,
John Holtz, P.E.
Senior User Experience Designer, Simulation
Autodesk, Inc.
Current version of Mechanical & Multiphysics: 2013 SP1 (2013.01.00.0012 28-Jun-2012)
Active Member
07-19-2012 03:00 AM in reply to: INACTIVE_AstroJohn
that in fact might be the problem.
I am ONLY using Autodesk Inventor Pro 2013.
I thought that maybe Autodesk Inventor Pro is capable of doing something like that.
Is Simulation CFD a software i can use as a student for free?
Thanks for all your help so far.
Regards
Max
07-19-2012 03:36 AM in reply to: maxluedemann
Hello Max,
the following programs will be able to help you solving your problems:
Autodesk Simulation Mechanical
Autodesk Simulation Multiphysics
Autodesk Simulation CFD
and furthermore a brand new cloud based solution should also be able to calculate (havent tried it yet but from what I can see on the download page it should be able)
Autodesk Project Simulus
The first three products should all be available as student version from www.students.autodesk.com the fourth is available for everyone (free) via www.labs.autodesk.com
HTH
Matthias
Nihil Ex Nihilo
Active Member
07-19-2012 03:48 AM in reply to: M.Peppel
Well, that would make sense why i havent found the things mentiond in the guide.
I looked at your link and wanted to download Multiphysics 2013 in a 64Bit Version, but did'nt find anything. Is there not 64Bit Version out yet?
There seems to be a bug or error, the german 64Bit 2012 Version only give me a "file does not exist" Error when i am downloading.
Thank you very much for your help and patience!
Yours sincerely
Max Lüdemann
07-19-2012 04:23 AM in reply to: maxluedemann
By the way,
es gibt eine hervorragende deutschsprachige Gemeinschaft von Nutzern der Autodeskprodukte. Unter www.cad.de bekommst du für alle vorgenannten Produkte hervorragende Unterstützung (ohne potentielle Sprachbarrieren, wenns ins Detail geht ).
Eventuell läßt du dich ja dort auch mal sehen.
Beste Grüße
Matthias
Nihil Ex Nihilo
Active Member
07-19-2012 04:42 AM in reply to: M.Peppel
Vielen Dank.
Ich habe mich da mal angemeldet, den ich denke ich werde noch einige Fragen haben :smileyhappy:
Ich bin dort unter dem Namen MaxL. angemeldet.
Vielen Dank für den Hinweis.
Gruß
Max
