Discussion Groups
Simulation CFD
New Member
karolvoo
Please, help me: model of bolt on the canal having a rectangular section
90 Views, 1 Replies
06-14-2013 11:22 AM
Hello.
I have a problem with CFD Simulation 2013 program. Now, I’m writing my engineering work. I have to do a model of bolt on the canal having a rectangular section. In front of bolt, water is crest up to 3,5 m. Behind the bolt is empty canal. In my work I must designate max water speed and pressure which action on that bolt. I have a model of canal, where the bolt is pick up to 10 mm for a bottom of canal, chunk of water. I don’t know how can I ascribe boundary conditions/initial conditions so as to water can flow in to the empty canal.
I must have this as soon as it possible.
Thanks in advance!
Please use plain text.
Product Support
wildej
Re: Please, help me: model of bolt on the canal having a rectangular section
06-16-2013 02:42 AM in reply to: karolvoo
I am not sure I follow.
What is a water crest of 3.5m?
You should be able to model a boat in water in CFD 2014 though, as we can account for the free surface of the boat, is that what you are running?
You would have a boundary condition for flow on the water only. Is the boat assumed to be moving?
Jon
Jon Wilde
