Discussion Groups
Simulation CFD
Member
Accepted Solution
Orthotropic material - 'element' or 'material' axis?
80 Views, 1 Replies
09-27-2013 06:52 AM
Hi to everybody.
Because I have to use an emispherical and thin solid dome, immersed in a fluid domain, and it is made by conductive plastic material (it is obviously orthotropic), I didn't found, reading documentation, any indication about how to build a 'Local Coordinate System'
So, I should like to know if X Y and Z axis (indicated in Material Database panel) are global or local.
If they are global, this is a serious limit to this very fine software; if not, I really will appreciate any help to resolve this issue.
Many thanks
       Piero
Piero Cirrottola
Please use plain text.
Product Support
Royce_adsk
Re: Orthotropic material - 'element' or 'material' axis?
09-27-2013 03:12 PM in reply to: picirrottola
Hi Piero,
The X, Y, and Z material properties are based on the global coordinates and you cannot define local material properties.
This would be an excellent comment to add to the idea station.
http://forums.autodesk.com/t5/Simulation-CFD-IdeaStation/idb-p/82
-Royce
Royce Abel
