CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Non uniform flow boundary condition
2 REPLIES 2
mahmadi
426 Views, 2 Replies
I am simulating a fairly long-narrow channel. I am planning to do the simulation in sections (to reduce the file size and simulation time and risk of failing). is there anyway I can use the flow/temperature distribution at the exit of one section as the inlet boundary condition of another simulation? how?
Thanks alot for your help in advance
M. Afshin
Tags (1)
2 REPLIES 2
Jon.Wilde
in reply to: mahmadi
The only way really is to use the bulk calculator to measure the average values on a plane at the outlet and then apply this as inlet Boundary Conditions on the next model.
Jon
Royce_adsk
in reply to: Jon.Wilde
I would give this request kudos since it seems to be the same request.
http://forums.autodesk.com/t5/Simulation-CFD-IdeaStation/Mapping-Velocity-Pressure-results/idi-p/434...
Royce.Abel
Technical Support Manager
